1996 Ford Mustang with LS1 383ci - Turbocharger T88
Old 04-23-2012, 05:42 PM
super-ss's Avatar
Smile 1996 Ford Mustang with LS1 383ci - Turbocharger T88
Mustang 1996 GT
AJE k-member
Engine LS1 383ci
Engine with Edelbrock intake manifold
My Engine on my stang
Soon, I'll add the new photos for my project step by step.
Old 04-24-2012, 09:31 PM
super-ss's Avatar
who's can help me about VSS for TH400, where i can find it ???
Old 04-26-2012, 07:31 PM
MillsMotorvation's Avatar
Dakota Digital has them, lokk on lt1swapcom, it help me a lot, has info on how to build harness and all. Brendan is a great guy!
Old 04-26-2012, 07:39 PM
WhiteKnight '01's Avatar
Wow, I want to see this.
Always humors me when I find people putting LSX engines inside a Mustang, how many Ford engines go inside Camaros?
Old 04-30-2012, 02:17 AM
super-ss's Avatar
Thank you guys for your replies
Old 09-16-2012, 10:49 AM
super-ss's Avatar
Hi All,
Please i need your kind support for help me.
I had code P0122 for throttle position sensor and the engine isn't started.
thanks
Old 09-17-2012, 10:39 AM
S8ER95Z's Avatar
Did you check the voltage of the TPS?
Old 09-17-2012, 10:43 AM
super-ss's Avatar
Hi S8ER95Z,
No i didn't check. Do you think it is reason for the engine isn't started ??
Thank you for your replay.
Old 04-19-2016, 03:30 AM
super-ss's Avatar
Hi Guys,
I sold my car "BoostedBarney" before one year. Now I bought it again without Engine and Turbocharger.
Now I will start again working on it.
First thing I am working on the Transmission "TH400".
This is what i found it from inside.
Attached Thumbnails 1996 Ford Mustang with LS1 383ci - Turbocharger T88-img-20160408-wa0009.jpg   1996 Ford Mustang with LS1 383ci - Turbocharger T88-img-20160408-wa0010.jpg   1996 Ford Mustang with LS1 383ci - Turbocharger T88-img-20160408-wa0013.jpg   1996 Ford Mustang with LS1 383ci - Turbocharger T88-img-20160408-wa0014.jpg
Old 04-19-2016, 03:39 AM
super-ss's Avatar
For Transmission I ordered the below parts for rebuild:
  1. Hughes Performance Automatic Transmission Sprags and Sprag Assemblies HP2279
  2. TH400 GAPLESS SPIRALOCK INTERMEDIATE CLUTCH SNAP RING
  3. TH400 INTERMEDIATE CLUTCH SNAP RING SUPPORT
  4. FTI TH400 U-BUILD-IT RACE KIT TURBO 400 F4019-4
  5. TCI Automatic Transmission Front Pump 213400
  6. Hughes Performance HP2252
Attached Thumbnails 1996 Ford Mustang with LS1 383ci - Turbocharger T88-hup-hp3751h_w_ml.jpg   1996 Ford Mustang with LS1 383ci - Turbocharger T88-s-l500.jpg   1996 Ford Mustang with LS1 383ci - Turbocharger T88-hup-hp3779_w_ml.jpg
Old 04-19-2016, 03:43 AM
super-ss's Avatar
For Engine I need your suggestions to go with:
- LQ9 block (Forged pistons and connecting rods) with 317 heads
or
- LQ9 block (Forged stroker 416) with 317 heads
My target is 900 to 1000 whp.
Old 11-22-2016, 02:04 AM
super-ss's Avatar
Before two weeks I bought a L76 engine and I ordered the Turbo camshaft, ZR1 head gasket, ARP head bolts and 85cc Injectors.
I am working now on E38's ecu with Electric throttle body & Pontiac G8 pedal.
Old 11-22-2016, 02:25 AM
super-ss's Avatar
The first step connect the ecu to the HPtuners
Old 11-22-2016, 12:26 PM
Cheese Weasel's Avatar
Hey, greetings from Colorado... Good to see that you're still working on it. Any pictures of the car??
Old 01-25-2017, 03:26 AM
super-ss's Avatar
@Cheese Weasel, thank you. I will add some pictures soon
Old 05-16-2017, 04:47 AM
super-ss's Avatar
Default In the start of this year
In the start of this year I came back to work on my Mustang
those pictures before take to my friend work shop
Without Engine or Transmission
Old 05-16-2017, 11:44 AM
Nali6.2's Avatar
awesome frame rail
Old 05-16-2017, 05:48 PM
super-ss's Avatar
Default Feb 2017
In the work shop:
Old 05-16-2017, 05:57 PM
super-ss's Avatar
Default Here's ready for drag
Engine, Transmission and others:
  • L76 stock bottom
  • ARP heads studs
  • Fast #85lb
  • Custom Camshaft
  • DOD delete kit
  • TH400 Full manual valve body
  • 2800 Torque converter
  • T88 turbocharger
  • 60mm Waste gate
  • 3 Intercooler
  • Weld star wheels
  • Aeromotive fuel regulator
  • Sparco Seats
  • Aeromotive Fuel pump A1000 - external
  • AJE k-member with A arms
  • AJE cross-member for transmission
Old 05-16-2017, 06:04 PM
super-ss's Avatar
Default The plan is changed
Drag car to Drift car
Here's the first look after remove the Turbocharger with new SVE wheels
Rear: 17 x 10.5 - 315/40-17
Front: 17 x 9 - 245/45-17
Rear wing: S281
I also change the Trans to TR6060 from 2012 camaro
Quick Reply: 1996 Ford Mustang with LS1 383ci - Turbocharger T88
