My 67 camar0 LS1/4l60 swap thread
#61
those hose forming coils arnt worth a bent dick.... so I made a bracket for the hoses out of aluminum and mounted it to the inner fender.
I also mounted the cruise control module (2001 s10) and routed / hooked up the cable. Need to wire it up, I got a 89 corvette turn signal lever (one of the few gm levers without wiper controls with cruise buttons) and a stock 70 chevelle lever and will figure out a way to make the corvette lever use the chevelle mounting tab, so it will bolt right on to my stock column and put the lever in the stock location
car was running super rich and was mis-firing on cyl #6 so new oxygen sensor (local autozone only had 1) is on its way from rock auto (and new plugs).
I installed the radiator braces from summit last night as well, nice heavy billet, very happy with the quality. pics to follow.
#62
Sooo I've got about 160 miles on it now, just checked all the exhaust bolts, and the 02 sensors fixed the rich condition and the plugs/02's fixed the mis-fire i was getting. The car runs really nice.
Comparison of old vs new u bolts...
and here you can see the new support braces (fuzzy) and the cruise module installed by the brake master cyl.
#63
Sam
#66
first thing, do you have a double acting brake switch? (1 normally open/i normally closed) you need to hook up both sides correctly and they both need to cycle once per key up or the modules ready flag wont set, and you wont have cruise. I wired the speed input from the ecm's speedometer output. Ign and ground are pretty obvious, as well as the control switches. what cruise module are you using? I used an 01 s10 module that doesn't require the "cruse enable" from the PCM that the newer camaro/gto ones do.
#67
Sam
#68
I've had 2 other issues adding this style cruise to other cars, one time the connectors pins had "relaxed" and wern't making good contact to the module, the other time the "good" servo i had gotten ...was bad.
hope it helps... BTW got any pics of your car/ interior?
#69
if you have acess to a tech 2 or similar, see if the cruise enable is ready in the PCM. it could be looking for somthing (wheel speed sensors??) that was not disabled in your tune and so now the PCM thinks somthings wrong and wont set-cruise enable...or go to a junkyard, and put in an s10/blazer module and all the other wiring will be the same and you'll be good to go.
Here is the link to my build
http://www.ls1tech.com/forums/conver...9-ta-vert.html
Sam
#70
Sam
#71
its a direct plug in..... I looked at ebay item # 300286937732 for a refrence of your plug, it does mean you'll need a 4.3L s10 cruise cable to go with it, as the module mount is diffrent (mine came with my s10 box)
#74
Sam
#76
Drove the camaro to work for the first time yesterday, about 55 miles each way, 1/2 mile down the road i hit a bird and brake my original grill, new one is on its way..
where the bird broke the grill..effin robin
Cruise stalk made from 70 chevelle and 89 corvette parts
#77
thats looks awesome. a classic car with cruise control on it. oh and gotta watch out for those crazy animals. i hit a deer few years back and busted out my headlight and turn signal and cracked my fender. sucks but thats nature.
#79
BTW your build is very nice. these are one of the cars I will someday own. just a matter of time
#80
haha. I hit a pheasant going 110 mph in my iroc-z with the t-tops off. My brother was in the passenger seat and it hit the top of the windshiel on his side. He looked over at me and said, "what's on my face?" He looked like Jack the ripper with the blood all over his face and hair. Good times. All birds can do major damage though.
