msd 6010 mounting ideas??
Old 02-23-2010, 02:50 PM
jasonsnova's Avatar
Default msd 6010 mounting ideas??
where is everyone mounting there msd boxes? i was thinking of mounting it in the car under the dash but i'm not sure the harness is long enough... i'd like to see some pics....
Old 02-23-2010, 03:32 PM
xpndbl3's Avatar
I put mine in the kick panel of my camaro inside the car. Then ran the serial port up the center console and into the CD holder area. Totally stealth but easy to change set points. If you drill a hole under your heater box area you have plenty of wire length if you take your time.
Old 02-23-2010, 05:49 PM
71 chevy's Avatar
Im planning to put mine in the car. only concern is the big flipping hole one has to drill in the firewall to get the plug through.
Old 02-23-2010, 07:05 PM
jasonsnova's Avatar
as lone as the harness is long enough i'll be good then!
71 chevy this is what i am planning on to get by the big hole....
http://www.summitracing.com/parts/SIT-SGS3-5-100/
Old 02-23-2010, 08:05 PM
S10xGN's Avatar
I put mine on a drawer slide, it pulls out from the dash. I added an aluminum plate with a fake radio graphic on it...
Attached Thumbnails msd 6010 mounting ideas??-100_0932s.jpg   msd 6010 mounting ideas??-100_0946s.jpg   msd 6010 mounting ideas??-100_0968s.jpg   msd 6010 mounting ideas??-100_1091s.jpg
Old 02-23-2010, 09:12 PM
jasonsnova's Avatar
cool ideas, ideally if i have enough cable i would like to put it on the backside of the glovebox door so its hidden and easy access .....
Old 02-23-2010, 09:57 PM
BigDaddyDupree's Avatar
mines on the passenger side kick panel in my s-10
Old 02-23-2010, 10:07 PM
71 chevy's Avatar
how did you guys get the connector through the firewall?
Old 02-26-2010, 09:54 PM
S10xGN's Avatar
I used a "Seals-it" grommet (see arrow).
Old 02-26-2010, 10:53 PM
71 chevy's Avatar
thanks man
Old 02-27-2010, 10:03 AM
Horsepwraddict's Avatar
I put mine in the glove box of my s10. Hidden away and easy to access.
Old 02-27-2010, 07:13 PM
jasonsnova's Avatar
Thats what im planning if it will reach!
Old 02-28-2010, 07:24 PM
71 chevy's Avatar
do you have the box yet? the harness is unbelievably long
Old 03-01-2010, 06:45 AM
jasonsnova's Avatar
yes i have the box... gonna set the engine in then mount, definatly going under the dash, i would like to mount it on the glove box door if it will reach
Old 03-01-2010, 09:43 PM
S10xGN's Avatar
If it's gonna be buried, you can always use a serial extension cable permanently attached to the MSD, coiled up and stashed under the dash for future programming...
Old 03-02-2010, 12:58 PM
68 RS Convertible's Avatar
I made up a mounting plate out of aluminum and mounted mine off the back two bolts of my intake.
Old 03-02-2010, 03:44 PM
NOPANTS-68's Avatar
I machined a two piece bulkhead and attached it with some stainless hardware. I mounted the box inside under the dash and routed the harness through a hole slightly larger than the largest connector.
Old 03-02-2010, 04:53 PM
forcd ind's Avatar
i mounted it on my heater in my Chevelle-the wiring was long enough
Old 03-02-2010, 09:40 PM
71 chevy's Avatar
would you machine these for sale? and how much?
Old 03-03-2010, 01:21 PM
NOPANTS-68's Avatar
never really thought about it. Let me see what it would take to do and cost.
Quick Reply: msd 6010 mounting ideas??
