LSx TTY bolts.
Old 02-25-2010, 05:46 PM
Jimbo1367's Avatar
Default LSx TTY bolts.
Are there any bolts on the LSx engines that CAN be reused? I understand you need to replace head,harmonic balancer bolts. But does this hold true to the intake manifold (including TB) waterpump & timing cover?
thanks,
Jim
Jimbo1367's Avatar
& oilpan?
Old 02-25-2010, 05:50 PM
caddy03pimpin's Avatar
IYou can reuse the WPand TB/Manifold bolts.
Old 02-25-2010, 07:10 PM
Jimbo1367's Avatar
ok, TY. what about the oilpan bolts?
thanks,
Jim
Old 02-26-2010, 12:36 PM
gofastwclass's Avatar
I'm not sure on the pan bolts. I have never read anything saying you can't but when I bought the "muscle car oil pan kit" from GM it came with bolts so I used them and they along with a new gasket were already on the pan. I don't see why you can't, all the torque to yield fasteners use the x ft/lbs of torque plus y degrees method for installation. The pan, valve covers, intake and accessories don't use that method.
Old 02-26-2010, 06:54 PM
Jimbo1367's Avatar
Default Bolts
[QUOTE=gofastwclass;12952273]I'm not sure on the pan bolts. I have never read anything saying you can't but when I bought the "muscle car oil pan kit" from GM it came with bolts so I used them and they along with a new gasket were already on the pan. I don't see why you can't, all the torque to yield fasteners use the x ft/lbs of torque plus y degrees method for installation. The pan, valve covers, intake and accessories don't use that method.[/QUOT
That is a nice observation. Thanks guys
