66 Impala sedan 5.3/4l60 air ride
Just started on my 66 Impala sedan 5.3/4l60 swap. I already did a 62 bel air and I don't think the 66 will be as hard, more room. The bel air was a cake walk, so i'm excited.
I just pulled a whole 5.3/4l60/harness/pcm/radiator/hoses etc out of my trans am to donate to the swap. I have AS ported 5.3 heads for the motor and a small 218/228 .550 cam. It will for sure get the cam, i'm up in the air whether I want to use the heads on a cruiser though. Picking up some gray center Boss 338 20s to put on it also.
Here's the car when i brought it home. Straight body no rust anywhere and a perfect interior! I'm into 4 door cars lately because they are so easy to find in good shape. I'll post up a photoshopped pic of one like it for reference on my plans.
I've been plugging away at the project, getting all the BS stuff done.
I sprayed the engine bay epoxy black, firewall, fenderwells, crossmember. It looks real clean and sano, especially fo just spending a couple nights on it. It was super clean already so wasnt a big project.
I installed the cam, valvesprings and pushrods in the motor, cleaned it up, and painted the block, fast intake, and front cover storm gray tonight. I need to do the valvecovers next and clean the heads a little more and it will be ready to drop in when the motor mounts arrive.
intake
motor
intake
motor
Hey yeah....
I did something similar with an LT1 & 4L60 E
Fast comfy car!
Kept it looking stock but she was speedy!
Drove it every day to work. Added disc brakes to help stop it.
Also had HID's for the Hi Beams. Awesome lighting!
Fast comfy car!
So I dropped the motor in today. No problem right>? LSX swap mounts and just bolt it in like usual? NO. Of course not. The oil pan decided it and the steering linkage needed to fight for position. 2 solutions: build mount stands to keep the pan above the linkage, or notch the pan. Well who guesses what I did? I busted out the FABracadabra skillz and built some stands real quick to mount it higher up. This will be fine for a while until I am able to get the pan notched and then I can get the trans angle closer to 0*. Its not bad right now but it still pisses me off. All I did was drill a center hole in the stock crossmember and bolted the trans in, cake son, cake. And what do ya know, the F body Pacesetter longtube headers fit like a glove, they even drop in from the top. Lots left to do but its in.
I guess that's why I always build my own stuff, thank The Great Pumpkin I have decent fab skills.
Looking good. What are you doing for AC or are you going that route? Nice Photoshop, hahaha.
What about changing the oil pan to a different profile?
Check out this thread: https://ls1tech.com/forums/conversio...-oil-pans.html
I'll keep plugging away at it here and there and get it done. Guess i'm going to work on the harness next and get it ready to plug up.
Mine had A/C but tho I installed the engine with the A/C compressor I never used it. Makes me sneeze. Your ride has door posts, mine did not and when I drove with all the windows down, it felt like a convertible.
keep us informed
keep us informed
MY 1st post. Found your thread trying to find info on building a 66, 4 door specifically. Happy to see it was yours and we live in the same place.
I have the red 4 door. Revamping it now to be more like what we see on this site. My new Favorite site that is!
Loving your Thread.
I have seen your car around Nashville, we both live in MJ! I saw your car at Mikes alignment not to far back and almost broke my neck.
Man, I am excited to start doing some things to get my ride back on the road and got some plans stew-in.
I was talking to Tim, he just bought the 66 4 door post. He was telling me about the possibility of you helping me with some things with some compensation of coarse, though on a tight budget.
anyway man, when you get off the power tour I would love to link up with you and check out your ride first hand and touch bases.
I am in love with the photoshop lowrod you posted. that is pretty much what i am going for aswell. Im going to get some American eagle 225's though.
It would be very cool to see 3 66 4 doors cruising around Nashville.
Loving your Thread.
Hey Nashville! I am doing a 65 Bel Air 2dr post car, but just getting started. What pan did you drop in, was it an f-body or truck pan and how far off was it. I have an 07 lq9 with a truck pan and have not had the chance to try a test fit yet. Any good pics of the bottom side would be appreiciated!!
Thanks OutlawX
Thanks OutlawX
