Where can i get an fittings for stock rails, and basic ecu tune?
I have a 99 fuel rail that i need to hook up to my fuel cell. i got 8an fittings for return and 6 an fittings for feed. I was wondering where can i get fitting for the feed on the stock fuel rail and is it a 3/8 or 5/16 tube? also on the end there a schrader valve.can i usethat as the return and what fitting can i put on that.?
As for a quick tune.
I have a stock 5.3 engine from a yukon that i need to run into a project with just the basic needs. it has a electrical gas pedal no cable and an ls1 intake and 28lbinjectors, 85mm maf, and thats it. with a th35o behind it. I read that i need vats deleted, rear o2sensors, so on. i need to send it out today if possible if possible.
Thanks again for the help. ill post pics of my build once i get it turned over.
Summit racing for the fuel rail fittings. Many vendors to the right can do the ECM mod. I plan on using www.speartech.com personally. Do a search. its in the top menu bar. It took me a little while to find it. LOL
