Clearance prob with F-body water pump
Old 02-27-2010, 03:42 PM
cvman's Avatar
Default Clearance prob with F-body water pump
I have an 07 5.3. The F-body water pump is hitting the timing cover, preventing it from going all the way back. I would say it needs to go back another 1/8 inch, with the gaskets in place. I could make some spacers to fill the void, but I was wondering if anyone else had this problem with the F-body water pump on the truck blocks.
Old 02-27-2010, 03:47 PM
oct03gto's Avatar
Do you have the dod setup? Also, are you using the paper gaskets?
Old 02-27-2010, 04:23 PM
cvman's Avatar
I don't know what the DOD setup is. It's a stock F-body pump and I'm using the stock 5.3 aluminum gaskets with the cast in o-rings
Old 02-27-2010, 05:01 PM
gofastwclass's Avatar
What did the engine come out of? Or better yet, use the VIN and decode it. You need to know if you have VVT or DOD.
Old 02-27-2010, 05:11 PM
cvman's Avatar
2007 Tahoe. As far as I know, it doesn't have VVT. The timing cover had only one sensor in it.
Old 02-27-2010, 07:12 PM
According to this, your engine has Active Fuel Management (aka Displacement On Demand) with Flex Fuel (e85) capability. I thought those engines used a different (deeper) timing cover due to the cylinder deactivation bits. I'm not sure so don't count this with info from your favorite religion's owner's manual, it could be my mal-adjusted brain incorrectly filing something. I have never researched those engines beyond what I have stumbled across looking for other information, I'm merely tossing out ideas. I typically stay in the 2000 - 2004 range for this very reason.
Hope this helps.
Old 02-28-2010, 10:10 AM
V8Rumble's Avatar
It sounds like you'll want to double-check the depth of the crank pulley as well...
Old 02-28-2010, 10:12 AM
cvman's Avatar
Double check it how?
Old 03-01-2010, 10:50 AM
cvman's Avatar
Are there any numbers on the engine itself that would identify if it has DOD or VVT?
