truck harness and fbody cluster?
Old 02-28-2010, 08:48 PM
feldz82's Avatar
Default truck harness and fbody cluster?
does anyone know how or know if it's possible to use a truck harness with fbody gauges? I have a '01 truck harness that i made stand alone and i would like to use fbody gauges for my mustang project. I'm confused with the class 2 serial data wire since it runs to my obd2 port.
Old 03-01-2010, 11:49 AM
Inbred's Avatar
let me know when you find out. i just started a ls1 swap in my 96....
Old 03-01-2010, 07:58 PM
V8Rumble's Avatar
There's something that's just so deliciously WRONG about that statement...
I'll take a crack at it - I would guess (keep in mind I said "guess") that they'd work just fine together, since it's '01-ish. I'm pretty confident that the ALDL signal will be the same, but not 100% sure about the gauge inputs. (I'd be surprised if they were too different though.)
Good luck.
Old 03-02-2010, 06:39 AM
feldz82's Avatar
Good luck.
So do I tap into to the obd2 wire some how? my wire diagram shows pin 59 in the blue connector as a serial data to bcm, but the fbody harness pin 59 isn't used.
Old 05-30-2010, 07:32 AM
LS88FoxBody's Avatar
Any Luck Guys?
Quick Reply: truck harness and fbody cluster?
