Will a 2007 Denali alternator work on my s10?
Old 03-05-2010, 08:18 AM
tennerv8's Avatar
Default Will a 2007 Denali alternator work on my s10?
Im building a Lq4 and im keeping the truck accessories. I will be running a carb and msd box. The truck is a '91. With this alternator work? I guess its a two wire alternator. Its from an '07 denali. Can I wire this up correctly? Thanks fellas.
Old 03-05-2010, 10:10 AM
tennerv8's Avatar
Somebody has to know. Will this alternator even bolt up to Lq4 truck accessories?
Old 03-06-2010, 07:53 AM
tennerv8's Avatar
tTT....
Old 03-06-2010, 06:07 PM
sierrac3_s2000's Avatar
Is it from a new body style Denali or the old style Denali? Either will work. The difference is the NBS Denali has a separate computer that controls the alternator. The computer sends a Pulse Width Modulated signal to the alternator to vary its output based on demand of the vehicle. If this is the one you have then only hook up the alternator "on" from the ECU which should be 12v through a resistor. This will default the alternator to 13.8 V charging. I have been running mine in my 240SX like this for quite some time and no problems.
