aluminium t56 driveshaft to 8.8 options
Old 03-15-2010, 05:32 PM
jeejee's Avatar
Default aluminium t56 driveshaft to 8.8 options
what would be the best / cheapest option in getting the t56 driveshaft to fit the 8.8 flange ?
is there some sort of bastard u joint ?
thanks
Old 03-15-2010, 08:07 PM
Kory 88Iroc Lt1's Avatar
I used the mounting pad from the origional 8.8 driveshaft it fit perftectly on the u joint from my aluminum driveshaft that was origionally in my Iroc.
I hope this makes sense.
Kory
Old 03-15-2010, 10:26 PM
Ken Reid's Avatar
I installed a shortened driveshaft from a 2001 Tahoe in my '49 GMC with 8.8 Ford using a spicer type rear u-joint (Neapco 2-1569). Lot of Chevy trucks used this rear u-joint, so you should be able to buy one most anywhere.
Old 03-16-2010, 01:43 AM
the_merv's Avatar
It's probably just a conversion U-joint that you need..I'm using one to go from my LS Driveshaft to the Yoke on my 9".
Old 03-16-2010, 09:19 PM
davev78's Avatar
8.8 ujoint flanges come in 2 ujoint sizes:
1330 - 97 up explorers
1310 - old style boxy explorers
Flange on axle is the same so either will work on your axle, easy find in junkyards.
Not sure what ujoint fbodys use, but now you are halfway to finding the bastard ujoint you need.
Old 03-17-2010, 12:42 AM
the_merv's Avatar
LS1 Aluminum is a 1330, the Steel DS is a 1310.
Quick Reply: aluminium t56 driveshaft to 8.8 options
