Battery CCA
Battery CCA
Does anyone have an opinion on minimum requirement for battery Cold Cranking Amps for my LQ4? The battery placement in my '65 Corvette is quite compact so I need the smallest battery that will work. Of course the smaller the batt, the less available cca's. The car will not be run in too cold of weather and will be well maintained. Terminal placement or style is irrelevant - I can wire anything in. I can get a pretty small batt @ 480 - 500cca but I fear that won't do the job. Price is not an object..
Thanks, Frank
Thanks, Frank
If you don't have cold weather starts and replace the battery on a regular interval than you can get by with a lot less battery. The battery I am unsing on my LS2 motor seems half the size of the one I had on the original inline 6. But for a summer only car it is more than enough. Bigger CCA is only margin for longer life and tough starts.
I did buy a $40 Battery Tender Junior to the keep the battery alive through the winter. Letting a battery sit partially charged in cold weather really takes the life out of them. The battery tender works perfectly.
I picked out the battery I have by walking the aisle at Sears and Walmart until I found one that looked like the size I wanted.
Have you thought about the "street rod / car audio" batteries? I have one in a different (non Gen III) project that is 1/3 the size of a normal battery and is sealed gel style. I can't remember the name of the one I have but it looks similar to this but is a different brand. I'm thinking of putting my second one in the Thunderbird and if I do I will report how it works out.
Frank, I know a little about batteries, maybe I can help. Stay away from a 'gel' battery, instead look for an AGM battery. AGM is for Absorbed Gas Mat, it's totally different from a gel battery. An AGM battery can be mounted in any position, even upside down, there are not venting issues or fumes to contend with either. Some of us street rodders will mount these batteries in the passenger compartment, even under the seats. Here is a link to a good source, XS Power batteries.
Also as Pop mentioned, use a Battery Tender (the brand name). I keep them hooked up to our Harleys 24/7 when parked in the garage. The BT will keep the battery at 100% charge all the time, they will also greatly extend the life of a battery, I get 5-6 years life out of the small Harley batteries (they are also AGM).
Hope this helps,
Mike
Hope this helps,
Mike
Great info fellas, thanks. I've never heard of agm bateries, I'll look into them. I do use a battery tender and do experience much extended battery life in my Harley's as well. So with keeping the fact that I do 'tend' my batteries I need to know some opinions of the minimum cca's that I could get away with for a 6.0l in non-extreme conditions.
Thanks, Frank
Thanks, Frank
