temp gauge adapter 12mm 1.5 x 3/8 NPT ?
Old 03-26-2010, 06:55 PM
Dickie-311's Avatar
Default temp gauge adapter 12mm 1.5 x 3/8 NPT ?
what is everyone using for an adapter for there machanical gauges , the head on a LS motor is 12mm 1.5 .. my gauge is 3/8 NPT ..or is there an other way to make this work ?
Old 03-26-2010, 07:24 PM
Gray86hatch's Avatar
I have a addapter with a 1/8 NPT and just not use the 3/8 addapter. I have a Stewart Warner gauge and am going to have to turn it down just a touch. The autometer senders fit fine. For my efi temp I am using a stock sender.
Tim
Old 03-26-2010, 07:28 PM
Dickie-311's Avatar
Tim
I have a autometer machanical temp gauge i'm try'in to adapt from 12mm 1.5 to 3/8 npt
Old 03-26-2010, 07:47 PM
Not going to find one. Switch to a electric gauge.
Tim
Old 03-26-2010, 08:08 PM
Dickie-311's Avatar
Tim
i may just drill and tap the flat spot on the top of the water pump 3/8 NPT
Old 03-27-2010, 04:42 AM
LS1MCSS's Avatar
Can you do this to it?
https://ls1tech.com/forums/conversio...-approach.html
Old 04-02-2010, 05:00 PM
Dickie-311's Avatar
problem solved... drilled and taped my water pump 3/8 NPT
Old 04-02-2010, 05:29 PM
blk96406's Avatar
NICE!!!!!!
Ive been kicking it around for awhile now......... glad to see it actually works out.
Old 08-08-2011, 02:04 AM
Camaro Chris's Avatar
S&p performance makes an adapter, It's like 18$
Old 08-08-2011, 06:59 AM
garys 68's Avatar
I drilled and tapped the drivers side block plug for 1/2" NPT.
Old 08-08-2011, 07:32 AM
Pop N Wood's Avatar
Yeah, the block plug easily taps to 1/2' NPT. From there you can adapt it to just about anything.
People keep trying to put mechanical gauge senders in the head, but like you will find out 12 mm is so small that any adapter you use will put it too far outside the head. For a 3/8 sender you can drill and tap the head to fit. Don't go larger than 3/8 in the head though.
For larger senders it is better to do some alternate location like the WP, block or even into one of the radiator hoses.
Old 03-17-2012, 05:46 AM
Goldhawg's Avatar
Gary--
Why did you go 1/2" NPT? Is your temp sensor not a 3/8 NPT? I'm trying to figure out where to put mine now. Do you have a pic of the location? Based on the above I'm giving up on the adapter and wanting to decide the safest place to drill and tap with the engine in the car (but not coolant in it).
Attached Thumbnails temp gauge adapter 12mm 1.5 x 3/8 NPT ?-temp-sensor.jpg
Old 03-17-2012, 08:03 AM
garys 68's Avatar
On my 68 corvette swap, the sender was 1/2" NPT, easy choice.
If you look at it, it's an allen head plug. If you drill the center for 1/2 NPT, it barely removes the 6 flats inside and gives a lot of material to thread.
Just flatten two opposite sides of the plug flange so you can put a wrench on it and tighten.
No pics, but it's the brass plug in the block under the #7 cylinder.
Old 03-17-2012, 04:49 PM
Goldhawg's Avatar
Just to be sure, you're referring to this one? Also, what's the best way to get that out w/o a giant allen head?
Attached Thumbnails temp gauge adapter 12mm 1.5 x 3/8 NPT ?-water-port-.jpg
Old 03-17-2012, 07:29 PM
oldngray's Avatar
Default tool
If you do not have the correct size allen wrench, go thru your bolt assortment for a bolt head that fits the allen socket, double nut it, tack weld the double nuts, and you have your removal tool......
Old 03-18-2012, 01:44 AM
garys 68's Avatar
That's the plug. Looks like a trip to harbor freight for a giant allen wrench that you'll use once in your life. Might as well pick up a 1/2" NPT tap while you're there.
Old 03-18-2012, 07:38 PM
Pop N Wood's Avatar
See post #11 for a pic.
And like oldngray says just use a bolt head instead of buying an allen wrench.
Old 03-19-2012, 07:41 PM
t72ss402's Avatar
I jusy ordered these from speedway motors.
16mm-1.5 Male to 1/8" Female For the oil pressure. http://www.speedwaymotors.com/LS-Ser...ter,20928.html
12mm-1.5 Male to 1/8" Female for water temp. http://www.speedwaymotors.com/LS1-Wa...pter,8195.html
I should get them tomorrow and will let you guys know how they workout.
Attached Thumbnails temp gauge adapter 12mm 1.5 x 3/8 NPT ?-adapter.jpg   temp gauge adapter 12mm 1.5 x 3/8 NPT ?-adapter2.jpg
Old 10-09-2014, 06:49 AM
JAYSS10's Avatar
That's for electric temp gage
Old 10-09-2014, 06:08 PM
ErikSOCAL's Avatar
Just want to make sure I have a clear understanding because I don't know all the ins and outs if gauges, sending units, elec vs mechanical yet.
I can use the autometer water temp gauge I had on my SBC (gen 1) mechanical gauge ( hard wire direct to a probe screwing into a port) by taping that plug for the right NPT?
If so that would be a nice savings of a few more bucks..
Quick Reply: temp gauge adapter 12mm 1.5 x 3/8 NPT ?
