68 camaro 6.0 question
Old 03-27-2010, 09:48 AM
Redrumls's Avatar
Default 68 camaro 6.0 question
Just finished the swap on camaro, carbed 6.0.
It idles fine but when you hold the throttle at a higher rpm it starts surging and sometimes pops out the exhaust? I don't know if I have a bad coil pack or I'm not getting enough voltage? Has anyone experienced this? I'm just burned out mentally.
Thanks
Old 03-27-2010, 11:25 AM
Redrumls's Avatar
need some help here or direct no to the right forum.
Thanks
Old 03-27-2010, 01:13 PM
yfz450's Avatar
had the same problem, i wasn't getting enough voltage on my msd box
Old 03-27-2010, 02:11 PM
Redrumls's Avatar
thanks, I'll try that.
Old 03-28-2010, 06:13 AM
Old Kid's Avatar
Lots of the old point ignition cars had a resistor wire going to the coil. If you use this wire to feed modern ignitions systems you might have problems.
Old 03-28-2010, 08:01 AM
68 RS Convertible's Avatar
Mine did the same thing. Make sure your power wire is from a switched 12 v source. When I first wired mine up it was pulling power from a 6 v wire, so anything over like 3 grand it broke up and back fired.
Old 03-28-2010, 04:43 PM
Redrumls's Avatar
Thanks, I'll check to see if I have 12v, hope that's what it is, can't wait to drive it
Old 03-28-2010, 04:46 PM
xpndbl3's Avatar
You should really run a dedicated relay and fuse for the box with 10 gauge wire IMO direct from the battery and the ground ran back to the battery for no issues. Plus you can use it with a switch as an engine kill switch just in case.
Old 04-04-2010, 09:36 PM
Redrumls's Avatar
Talking
Thanks guys for the feedback! i was only getting 9 volts to the msd box, now im on a switched 12 volt source and it runs like a champ! finally drove it .
Quick Reply: 68 camaro 6.0 question
