Special fitting
it goes directly into the rear oil galley, a 16mmx10an will not work, no way to tighten it.
lot of guys use them for their accusump. I want to use a pan with no fittings on my awd, there will be no fittings down by the front differential.
http://www.pirate4x4.com/forum/showthread.php?t=816350 this is probably what you need, if your using a stock oil pan.
