2006 LQ9 pedal assembly
Old 04-03-2010, 09:18 PM
crosstraining's Avatar
Default 2006 LQ9 pedal assembly
Does anyone know where I can find a 2006 Escalade (or equivalent) gas pedal assembly? I have googled and can't find anything. Is it called something else? The only other option I can think of is looking through junkyards.
Thanls,
Brandon
Old 04-03-2010, 09:42 PM
rascalking's Avatar
The escalade throttle pedal is pretty bulky, but I have one if you are interested. I bought the Monte Carlo pedal and it's pretty nice. Its more compact and looks way better in a hotrod swap. The part number for the Monte Carlo pedal is 15831256. It has the same plug as the Escalade too. You can get it on gmpartsdirect.com for around $30.
Old 04-04-2010, 10:35 AM
rascalking's Avatar
Monte Carlo Pedal
Escalade Pedal
Old 04-04-2010, 03:49 PM
The Monte pedal looks good. I might use that.
Thanks
Edit: The Monte Carlo pedal is not compatible with 2006 LQ9 Escalade PCM & TAC
Old 04-04-2010, 07:43 PM
BuffJoeyD's Avatar
I might have one in the garage I'll check tomorrow.
Old 04-04-2010, 08:39 PM
That would be awsome, thanks
Old 08-11-2010, 10:52 PM
sylgeist's Avatar
I know this is an older thread, but I need to swap out my pedal assembly as well. I have a 2007 5.3 Gen IV motor with the giant plastic pedal. Is the Monte pedal pin compatible? It's the same connector, but I didn't want to assume!
Old 09-13-2011, 11:45 PM
Hans Grüber's Avatar
Will the Monte Carlo pedal work with an E38 ECM?
Old 09-14-2011, 08:25 AM
rascalking's Avatar
Hans, that's the combo I am using. based on the research I have done, it should work. But I haven't tested it yet. Maybe someone that has used it successfully will chime in. Good Luck.
Old 09-14-2011, 08:11 PM
If you find out it works PM me, and we can deal on the 1 I have.
Old 09-15-2011, 01:01 PM
1976CamaroGuy's Avatar
anyone know if the monte pedal will work in with a 2004 5.3 computer and tac module?
If so will the plugs interchange?
Old 03-01-2016, 10:39 AM
Zonurass's Avatar
I know this is old thread but did yall ever figure if the 2006 monte carlo pedal would work?
Old 03-01-2016, 10:56 AM
rascalking's Avatar
As usual, life has prevented me from progressing on my project, but I'm almost there. Based on the research, it should work, but you will need to swap 2 pins. See this thread:
https://ls1tech.com/forums/conversio...-corvette.html
Cheers!
Quick Reply: 2006 LQ9 pedal assembly
