vacuum line question....
Old 04-08-2010, 11:11 PM
Yellowbrother's Avatar
Default vacuum line question....
i have a vacuum line question....or i think it's a vacuum line...it's part of the stock harness...it's very small...one end goes towards the back of the engine...on the intake manifold or something back there...i cant see it with the motor mounted in the car already...but anywho...the other end shows up at the beginning bundle of the harness...close to the ecm...i have it connected to nothing...where does this plug into on the fbody??? it's a 2000 camaro harness...
Old 04-09-2010, 01:23 AM
LS1MCSS's Avatar
It connects behind the intake and the other end plugs into a line that goes inside to operate the heat/ac vent doors,,, I think.
Old 04-09-2010, 09:17 AM
ls1nova71's Avatar
Yep, that's what it's for. Just take it out, you don't need it.
Old 04-09-2010, 05:14 PM
dammit...one other crap to buy to plug that bitch with....thanx guys for the help...
Old 04-09-2010, 07:43 PM
Pocket's Avatar
Just cough up the $8 for an assorted vacuum plug kit. Youll need several before the build is done
Old 04-10-2010, 04:49 PM
04600rr's Avatar
question on the same lines.....what are you guys using to plug the evap purge solinoid on the intake?
Old 04-10-2010, 06:11 PM
Pocket's Avatar
Vacuum cap from the same kit
Old 04-10-2010, 07:02 PM
04600rr's Avatar
hum i have looked at kits and not seeing anything that will work.......it is a hole in the intake
Old 04-10-2010, 08:23 PM
ls1nova71's Avatar
On a car intake (LS1) it's a nipple you can put a cap on, if you're using a truck manifold it's a hole. Just leaving the purge solenoid in it with no power hooked to it will block it off.
Old 04-10-2010, 10:49 PM
04600rr's Avatar
my motor came without it, it is a truck motor. i will figure something out. might try to make a brass plug or something
