1959-1964 impala rear end housing strenght?
Before I rebuild the rear end on my 63 impala I'm wondering if it is safe to keep the factory housing. I have heard that it wouldnt be stronger enough to handle a ls2/4l60 swap by some and other said it should be fine. has anyone had problems with the rearend? are there any pro's and con's?
Dang! I want a cruiser I'm not dragging but every so often I would like hit it hard. I was going to rebuild everything in the rear but they say I would still snap the rearend. If you blew 4 rears with a 283 I may not have a chance with the ls2
Some of those cars came with 409s rated at 425hp. With your intentions I'd say it would be fine. In 7 years with a mild small block and quite a few trips to the track only problems I've had were I spit out a few spider gear teeth one night and I can't get the o rings on the bearings to seal so it leaks a little fluid all the time.
I have a 62 Biscayne with a roller 355,stall convertor and a turbo 350. I drive it hard, but I don't beat the thing to death.I'm running 20's on the back with heavy rims. The rear holds up pretty decent. Like the guy above posted they came with 409's and 400 plus hp. They lasted. Slicks or the track will be hard on it. But if your cruising a auto tranny is easier on the rear end that a stick car would be.
