front accessories g body 5.3 question?
I have a 5.3 that will be converted to carb, to be installed in a 86 monte carlo.
My question is can any of the truck accessory brackets be used? If not what will i need to go with? I only plan on running alt. and power steering. thanks
G-body 5.3l Swaps
My G-body swap was LS3 into 85 Monte using Corvette accessory drive w/ a/c, and Cadillac CTS-V oil pan. This arrangement tucks in close to the motor and gives you more space between the end of throttle body and radiator for your air inlet tubing. The alternator and power steering pump clear everything at the front of the g-body chassis great. (This accessory drive is also available w/o ac:
http://paceperformance.com/index.asp...&ProdID=248708
Other helpful G-body 5.3 links below:
https://ls1tech.com/forums/conversio...-owners-2.html
https://ls1tech.com/forums/conversio...-radiator.html
https://ls1tech.com/forums/conversio...swap-pics.html
http://www.google.com/search?hl=en&a...i=&safe=images (Courtesy of V8Rumble)
