lh8 pan on third gen ls1 swap
Old 04-16-2010, 08:50 PM
Roast1's Avatar
Default lh8 pan on third gen ls1 swap
has anyone used an lh8 pan for their swap? if so how was k-member clearance. also any ground clearance issues? ls1 is going in a 88 camaro
Old 04-16-2010, 11:05 PM
Pocket's Avatar
Do a search on TGO about it. Its 2" lower than the Fbody pan which is dead flush with the bottom of the K-member, so ground clearance is an issue. Truck pans are more compact so clearance around the K-member should be excellent
The Fbody pan will fit the best. 2nd best is the LS2 corvette pan, but those are hard to come by
Old 04-17-2010, 02:56 AM
white84z's Avatar
I would check into the LhX pan that Retro LSX offers. It has the same depth as the f body pan but almost as much sump clearance as a truck pan.
