jeep 5.3 witout 02 sensors
Old 04-20-2010, 01:25 PM
sleepy_boy1's Avatar
Default jeep 5.3 witout 02 sensors
hi guys, im running a 5.3 in my jeep wrangler, and im not running any o2 sensors, my jeep is running very rich my fuel consumption is very high.... i want to know should i put some o2 sensors on or can i just tune my jeep to run without o2 sensors...., running without o2 sensors would make my life easier..
Old 04-20-2010, 01:33 PM
bozzhawg's Avatar
You can get away with deleting the rear O2's but I believe you will need the front O2's....... I know that even if you don't run thr rear O2's and do not modify the ecm, it will run rich...... So I could only imagine if you run none at all......
Old 04-20-2010, 01:44 PM
Jimbo1367's Avatar
Are you runing truck or car EFI manifold?
Old 04-20-2010, 01:57 PM
Bo185's Avatar
Add the O2's thats why your getting shitty MPG. The PCM doesn't know what fuel trims to use so it defaults to set ones.
Old 04-20-2010, 02:00 PM
6.0Nova?'s Avatar
But leaded gas ( like they sell in the middle east) kills 02's. You can tune it open-loop-SD if you need to.
Old 04-20-2010, 04:44 PM
Bo185's Avatar
Yes overtime.
But, he'll get better MPG with the 02's/MAF closed loop.
I think he just needs to get the correct tune and that will fix the problem. IE a SD tune.
Old 04-21-2010, 12:41 PM
ok.. im going to sd tune and see what happens, we only have unleaded fuel here, we have 95 octane and 98 ocatne only,leaded fuel is no longer legal here, i thought we have one of the best fuels in the world....... i live in dubai... maybe other countries here use leaded fuel.... i guess
