Wire harness questoin ls1 into 95 ta
Old 04-20-2010, 01:25 PM
95_ls's Avatar
Default Wire harness questoin ls1 into 95 ta
ok so i was hooking up my engine harness after i had it modified to fit the lt1 car and i cant figure out where this one conector goes i know the harness is on right though maybe some one would kno... its a two prong connector that has a brown and black wit white tracer and seperate purple ground. its on the passenger side of the motor ne help would be great
Old 04-21-2010, 02:16 PM
95_ls's Avatar
or does ne one kno of a good wir diagrm i can look at???
Old 04-21-2010, 05:58 PM
LS1MCSS's Avatar
Post a picture of it. A purple wire shouldn't be a ground. Is it a #10 wire?
Old 04-22-2010, 09:16 AM
95_ls's Avatar
I will try to get a pic up by tomorow.. i dont think its as big as a #10 but im fairly sure its a ground bc it has an I-let on the end
Old 04-22-2010, 04:48 PM
Pocket's Avatar
Fat ppl wire is the starter solenoid. I can say with certainty because GM didnt use large gauge ppl wiring for anything else (except short lengths in FWD fuse blocks)
It has a ring terminal on one end approx 3/16" dia with a single inline connector on the other
Old 04-22-2010, 07:21 PM
flame's Avatar
The only brown and blk/wht I can think of is the low oil level sensor in the oilpan. As said above the purple is the starter solenoid.
Old 04-22-2010, 10:55 PM
95_ls's Avatar
i figured the ground was for the starter the low oil sensor is already connected but this wire runs in the same area?...
Old 04-23-2010, 11:34 AM
flame's Avatar
The purple wire is not a ground. Black wires are grounds. When you turn the key the purple wire is 12 volts to trigger the starter solenoid. Take a picture of the connector with the brown & black/white and we may be able to figure it out.
Old 04-23-2010, 05:36 PM
95_ls's Avatar
i figured it out i had my parts guy look it up on his data base i had two wires in the wrong place the connector wit the black and brown wire goes to the oil level switch and the other goes a connector by the flywheel... ne way thanks guys
Old 04-24-2010, 08:42 AM
Pocket's Avatar
There is no connector near the flywheel
Old 04-24-2010, 09:49 AM
95_ls's Avatar
i beg the differ ther is one rite by where the starter goes into the bell housing
Old 04-24-2010, 10:40 AM
1quickirocz's Avatar
i think you may be talking about the crank sensor
Old 04-24-2010, 09:32 PM
Pocket's Avatar
In that proximity, the crank sensor, cam sensor and oil pressure sender are both equally distant from the flywheel
There are no sensors that monitor the fly/flex or are in the general area of them
Quick Reply: Wire harness questoin ls1 into 95 ta
