Dipstick - LS1 Oil Pan on 2000 5.3l
I have a LS1 pan and everything I need to put it on but wondering about the dip stick. Will it still read right using the truck dipstick tube and dipstick?
Or can I just mark the truck dipstick? If so, since the truck hold 6.5L and the car holds 5.5L, do I just measure and cut it 1L shorter?
Truck pan is quite a bit deeper than the F-body pan. I decided to just buy a new F-body dipstick and tube to be safe. When it comes to fluid levels I didn't want to play a guessing game.
Truck windage trays were the generic full piece. Fbody's used a low profile pan and the front didnt fit anymore. GM simply whacked off the whole section for the front main cap. Its just like the truck tray, otherwise. So trim it and itll fit or use the Fbody piece
Both parts are about $20 brand new from a dealer so you're not really in a bind either way you go
