Heater hose bypass idea
I've read that the heater hose has to be looped if not used. I'm using a vintage air HVAC unit which closes off the water flow completely when not used, so I'd still need some type of small orifice between the hoses before they get to that valve.
How about drilling an 1/8" hole behind the thermostat for that constant bypass effect. (Through the divider between the flow paths that lead to / fro the heater.) It would allow a small amount of that flow and there would still be enough of a pressure differential to push fluid through the heater core when the cursed vintage air water control valve was fully closed.
Any thoughts? This would work well for anybody wanting to eliminate the heater hoses and still allow the car to warm up properly.
I use a 4 port heater bypass valve.. it will route the flow back to pump. It is vacuum controlled (but you can also find them cable controlled) and I think they are for GM Trucks and van's. I did a google on "suburban heater valve" and found many hits.. here is a sample
http://www.autozone.com/autozone/cat...&parentId=52-0
http://www.autopartsdeal.com/catalog...e+Heater+Valve
But any good parts guy should be able to find something that will work or cross reference something.
ive got a va system for my camaro (bought in 01 i think) my water valve worked fine till this year after my ls install. i just put a manual shutoff valve on mine, my water valve is up in the fender and a pita to get to
Thermostat housing part of WP:
Section showing modification:
That's the idea but I was just going to go in where the thermostat gets stabbed into place. It'd be one less hole to plug.
BTW, nice rendering. Solidworks?
