HELP!! it will only run on 4 cyl.
Car was running fine, put it on the trailer to take it to the alignment shop, when i went to take it off it has been running on the odd number cylinders since, drivers side! I have ohmed out the coil pack extensions and checked for 12volts on all pink wires going to the coils all seems to be good, but they are not firing!!
Any help will be greatly apperciated.
This is a coupe foxbody turbo ls1 swap
Thanks
Thanks
