ls1 steam line?
ls1 steam line?
i have heard i need a steam line in the top of the water pump. but when i do that were does the other end of the hose go too?
am runing a fast 92mm intake with a nick will. 92mm tb.
hey man, u got all the answer for me i have the cross over pipe for the front an it has a hose on it now for the dealer. so i though it went somewere eles. so i just need to drill the water pump an get a longer hose's for it to reach the cross over pipe then..
u dont have to modify the water pump i just cut out a section of upper radiator hose right in front of the radiator took a pipe that fit inside iit real well about 4 inchs long then drilled and welded a smaller pipe perpendicular to the bigger pipe right in the center of the 4 inch pipe. then just ran a rubber hose for the steamline from the crossover tube to the upper radiator hose. its much easier and doesnt risk messin ur pump up from metal shards
Here's a part that will work, or you can make your own.
http://www.jagsthatrun.com/Pages/Par...g_LSI-tee.html
