noise after a/c with aftermarket bracket
Old 05-11-2010, 04:03 PM
fptransport's Avatar
Default noise after a/c with aftermarket bracket
is anyone using the KwikPerf, brackett?
I had my 5.3 swap 84 silverado, and has been running great, but then I bought the kwickperf a/c bracket and a compressor, after installing it, I nocited thats is a noise coming from one of the pulleys, but they are all new, and properly thight, winding noise is getting on my nerves... any help, Ideas are appreciated...
added: I can also see, belt "dust" around the pulleys,, where the belt is getting damage slowly but is not rubbing on anything
Old 05-11-2010, 08:38 PM
rotor vs. piston's Avatar
Not really close to the same, but I have a relocated alternator and my pulleys are pretty noisy. But I don't have a factory GTO to compare it w/. The noise actually goes away after a while, but it's there the first while the engine is on.
Old 05-12-2010, 07:01 AM
Old Geezer's Avatar
The belt on the Quik combo has to go on the outer ribs.. Put it on wrong, and you'll get what U R seeing...
