Shopping List - LQ4 into 69 Camaro
Hi All,
I am planning to put an LQ4 into my 69 camaro. I already have an LS1 Intake, T56 and an Aluminum SBC Radiator with the Lincoln Mark VIII Fan. I want to put an order together with Frank at Prodigy Customs.
What am I missing?
ATS Motor Mounts
Energy Suspension Poly Mounts
ATS Crossmember
Dynatech Headers
Engine
Lokar Pedal
Misc
Oil Pan
ls7 Flywheel/Clutch
Harness/Fuel Rails/injectors
HP Tuners, Wideband
Alternator bracket
99 Vette Fuel Pressure Regulator
AN Fittings, hoses, etc.
Walbro 255 LPH Fuel Pump
Thanks,
Chris
What am I missing?
ATS Motor Mounts
ATS Crossmember
Dynatech Headers
Engine
Lokar Pedal
Misc
Oil Pan
ls7 Flywheel/Clutch
HP Tuners, Wideband
Alternator bracket
Thanks,
Chris
Im doing the same in my 67 got a hell of a list just started buyin stuff. Ur list is pretty much the same as mine but im puttin in a cam and springs and complete interor and body work and baggin it on 20s. The oil pan i found works good is a 4th gen camaro and pasesetter 4th gen race headers will work with a little mod to 1 pipe 264.00 is a hell of a deal compared to 700+. And if ur using truck harness u need ls1 injector pigtails.
