In need of aftermarket 6L80 auto shifter
Old 05-23-2010, 11:09 AM
SILVER BULLET's Avatar
Default In need of aftermarket 6L80 auto shifter
I am doing a LS3/6L80 conversion into a 67 camaro and the factory auto shifter from a 2010 is way too tall and would require a custom console to look decent. Due to its design and size it can not really be modified. I am looking for an aftermarket auto 6 speed shifter for the 6L80 that is shorter and less bulky.
I know the 09 CTSV has the same trans, but I don't know if the shifter is any smaller. Does anyone have any suggestions or ideas?
Worst case I will have to modify the tunnel to drop the shifter down
Old 05-23-2010, 01:44 PM
rascalking's Avatar
I'm looking for the same thing for my 6L and I'm thinking any aftermarket shifter for a 4 speed auto overdrive should work because the trans still only has a 1,2,3,4 shift pattern, at least thats what it looked like when I was playing around with it yesterday.
Old 05-23-2010, 02:05 PM
Yes I believe you are right, it has 2 overdrive gears. I guess we would need a push button for overdrive?
I do want to manually shift it like it was intended
Old 05-23-2010, 02:22 PM
rascalking's Avatar
Yeah, I agree. There has got to be some way to use an aftermarket shifter and still be able to utilize the TUTD function. Not sure if my computer will allow that since its actually from an escalade.
Old 07-01-2010, 02:03 PM
3stgstocker's Avatar
Default shifter tci?
im lookn 4 the same thing im doin a 6.0 6speed auto out a 09 g8 in a 79 chevy truck. talkd 2 tci 1 day they said there new outlaw shifter with the 2 buttons would work then calld back a week later 2 get the part number after i put the motor in the truck n they said they dont make 1 4 it so idk wtf 2 do now. i know somebodys got a 6 speed auto in a conversion we jus got 2 get them 2 chime in. this is holdn me up now bout got it done other than that part.
Old 07-01-2010, 07:33 PM
LS1MCSS's Avatar
http://www.twistmachine.com/Paddle_Shifters.html
Old 07-02-2010, 08:18 PM
http://mastershift.com/new-street-auto.html
I am using the sequential bump shifter. It is a one wire hook up and works with an auto & manual.
I can't claim how well it works because it isn't in the car yet. I will let you guys know
Quick Reply: In need of aftermarket 6L80 auto shifter
