1973 Nova SS - LS1/ T56 & 70mm Turbo - Done!
Old 05-24-2010, 10:01 AM
MeanYellowZ's Avatar
Default 1973 Nova SS - LS1/ T56 & 70mm Turbo - Done!
Been a long road but it looks like this one is ready to go. The car got bounced back and forth between body shops/ suspension shops, etc - but it looks like its ready to cruise now. This is one of those cars I would much rather NOT give back to the owner. The car cruises down the road effortlessly, put it in 6th gear at 70mph and it drives like a charm, but step into the throttle a little and the smooth running, great gas mileage getting LS1 turns into a beast. A little throttle at highway speeds results in tire spin with minimal effort. This car does everything you could want any hot rod to do. Can you tell I'm pretty fond of this one??
The basics:
73 Nova SS
Corvette LS1 - all stock except valvetrain/ turbo cam
GTO T56 - stock
Textralia clutch
12 bolt posi - 3.42 gear
Swap notes:
Hummer oil pan
BRP mounts (yikes, never again!)
Cut down F-body alternator bracket/ custom idlers
LS1 Intake
Aeromotive rails
15 gallon aluminum fuel cell
Bosch 044 fuel pump/ - 8an lines
Battery relocated to trunk
F-body radiator/ Perma Cool fans
Turbo setup:
Custom built piping based off C6 manifolds flipped
Master Power T70
Tial wastegate and blow-off valve
Manual boost controller
3.5" downpipe and exhaust w/ bullet muffler
Pics...
View My Video
Old 05-24-2010, 10:34 AM
hawiianpwr's Avatar
Thats is Badass!
Old 05-24-2010, 10:51 AM
frito1's Avatar
Nice turbo build! Looks like you have 15" Street Lites on. What tire sizes are you running? I like the stance and sidewall you have there.
Old 05-24-2010, 12:13 PM
eviltwin_1987's Avatar
You are always building the coolest stuff, look great!
Old 05-24-2010, 12:23 PM
No, YOU build the coolest stuff.... I think I have asked before, but do you have pics/ info on your 65 GMC somewhere?? I want to see more of that. I'm still plugging away on my bagged 59 GMC when time allows. I also picked up another project of the turbo/ LSx/ AWD Sy-"clone" type, and as long as time allows and I stick to it, someday I can be having some boosted AWD fun like you!
Old 05-24-2010, 12:53 PM
89LS1RS's Avatar
any idea what kind of power its making?
what psi is it running at?
what are the valvetrain mods?
Old 05-24-2010, 12:55 PM
350SS's Avatar
Great build, very clean install...
So, how's the ground clearance with the H3 pan?
How much did the trans tunnel need to be modded with the t56?
Old 05-24-2010, 08:15 PM
gofastwclass's Avatar
Another fine product by MYZ, nice job!
You make me want a turbo.
Old 05-24-2010, 08:34 PM
Lanaue's Avatar
Thats one nasty Nova!!! Great Job!
Old 05-25-2010, 12:16 AM
2XR95Z28's Avatar
Hey Randy, where do you have the vacuum line running too after it goes from the wastegate to the boost controller, then where does it run too after the boost controller? Thats the last vacuum line routing i need to figure out. And did u pick the vacuum line up local? if so where at?
Scotts car turned out perfect! Killler job!
Old 05-25-2010, 12:33 AM
ls1nova71's Avatar
Sucks you had to ditch the brake booster, must have been clearance problems with the exhaust? The last Nova I had that didn't have power brakes, you would about pull the steering wheel off trying to stop it in a hurry, and I didn't have nearly as much power as this car. Nice job though, makes me want a turbo too!
Old 05-25-2010, 12:34 AM
Fatbum's Avatar
Sick!
Old 05-25-2010, 12:49 AM
performinnorman's Avatar
Very nice. Such a clean install. Nicely done.
Old 05-25-2010, 02:23 AM
mac_z_28's Avatar
hey guys, im the owner of this nova. randy (meanyellowz) did a fantastic job. car drives awesome and the 2 times ive been in boost is ....stupid awesome! lol its official, im in love with a car
Old 05-25-2010, 11:22 PM
Car will be dyno'd the end of the week so power number will be coming. Setup to run around 8# now. Valvetrain consists of Texas-Speed turbo grind cam with matching beehive springs and pushrods
Ground clearance with the H3 pan sucks, that will be changed at some point. Trans tunnel got minor massaging and work around the shifter hole from the old 4 speed.
Old 05-25-2010, 11:26 PM
patriotformula's Avatar
Good work Randy... Car looks great in person and in pictures..
Old 05-26-2010, 10:19 AM
Double_Trouble99's Avatar
that ther be preety! lol looking good glad to see it finished.
Old 05-26-2010, 04:00 PM
67camaro's Avatar
Cleeean!
Old 05-26-2010, 05:08 PM
slownova73's Avatar
Hey man thats a sexy 73 ya got there...is it factory SS? if so its good to see another one with my stripes lol
Old 05-26-2010, 05:51 PM
MYSTIC-1SC's Avatar
awesome build. Ive always been a sucker for novas
Quick Reply: 1973 Nova SS - LS1/ T56 & 70mm Turbo - Done!
