Which LS2 accessory package
Putting a 06 GTO Ls2 in a 69 camaro with factory subframe. Purchase a GGPP Corvette accessory package with AC? Will the Ac fit with factory subframe or do I need to do something else? Does GTO water pump work?
You may want to look into another front drive setup because the corvette still has the compressor sitting low on the pass side just as the GTO which may cause interference on the fbody frame. A cheap alternative is the kwikperf.com a/c bracket and Sanden compressor which still allows use of the factory setup. Also, you're gonna need a different oil pan(modified f-body pan).
