LS1/t56 73 Corvette 12/1/10
Old 06-14-2010, 10:41 PM
meinthe73's Avatar
Default LS1/t56 73 Corvette 07-01-2012
started my summer project..
ls1 and t56 into my 73 vette
out with the old in with the new.....
almost perfect shifter fitment
i have another one of these for the t56 throw out bearing i paid 24 for two ill take 12 shipped so someelse dont have to order 2
Old 06-15-2010, 03:05 AM
ge_forcez22's Avatar
did you go from a cable clutch to hydraulic clutch? What did you all do?
-Garrett
Old 06-15-2010, 09:47 AM
meinthe73's Avatar
-Garrett
Im going from auto to manual, but it is going to be a hydraulic clutch.
Old 06-15-2010, 11:44 AM
oh ok. What are you planning on using for your pedal and master setup?
Old 06-15-2010, 09:48 PM
meinthe73's Avatar
its a custom pedal added to my stock brake pedal assemlby and a MC from a 85' silverado 1500
Old 06-15-2010, 10:22 PM
oh ok, do you think it woul be easy/possible to make my mustang clutch work with a GM master cylinder? Or should I buy a camaro pedal assembly?
Old 06-16-2010, 08:32 PM
meinthe73's Avatar
any thing is possible. if you already have the clutch pedal. try to find a MC off a mustang so it matches the angle of the firewall. you want that MC as parallel to ground as possible just so the rod when compressed goes in easy to reduce wear. what slave/throw out bearing are you using?
Old 06-17-2010, 07:15 AM
RicOtt's Avatar
I like the shifter location. Did you fabricate your own mounts - or buy from a vendor? If you purchased the mounts from a vendor, which one? I'm gathering parts right now to do a LQ9 / T56 into my 71 corvette roadster that I hope to begin this winter. My son and I are finishing up a LQ9/T56 swap into a 66GTO right now. The engine swap is complete and runs great, but we are on the last lap of restoring the rest of the car.
Old 06-17-2010, 10:49 AM
I just bought a used T-56 from LT1-ovrkill IIRC, and it has a Wilwood 7/8" master, and I believe a new style ACdelco slave with Centerforce DFX clutch. Tranny was rebuild with a Tick stage 2 rebuild in april, so all pretty fresh.
Just gotta figure out if I can build a "plunger" off the mustang clutch pedal... should be pretty doable with a welder and a drill .... here's hoping, lol
-Garrett
Old 06-17-2010, 10:53 AM
performinnorman's Avatar
Awesome. Keep us up to speed on your progress.
Old 06-21-2010, 01:01 PM
meinthe73's Avatar
sorry the late response.i used these exact plates as these. For only 32 dollars it was pretty sweet
http://cgi.ebay.com/ebaymotors/LS1-C...item3f004d9585
Old 06-21-2010, 01:02 PM
meinthe73's Avatar
Can someone please inform me on how to wire up a water temp gauge? thanks
Old 06-21-2010, 01:08 PM
garys 68's Avatar
Are you trying to use the stock gauge? If so does your sender have a 1/2 NPT sender like my 68?
Old 06-21-2010, 01:34 PM
meinthe73's Avatar
honestly im not sure. what would it look like?
Old 06-21-2010, 02:25 PM
garys 68's Avatar
It will be near the front of the old intake manifold.
I tapped the drivers side block plug on my 68, still using that.
See my post in this thread for other options.
https://ls1tech.com/forums/conversio...auge-59-a.html
Old 06-21-2010, 04:49 PM
meinthe73's Avatar
well i think i lost my original. you think it would be possible to tap into the temp wires on the drive side?
Old 06-21-2010, 05:26 PM
RTRx7's Avatar
You're lucky to have that perfect fit.
Old 06-22-2010, 01:47 AM
garys 68's Avatar
Nope, not unless that's a 98 camaro motor. Btw I can see the sensor in the pic of your old engine.
Old 06-22-2010, 09:51 AM
meinthe73's Avatar
damn i sold that motor. would the temp sensor on the passanger side work if connected to an electrice gauge?
Old 06-22-2010, 03:26 PM
garys 68's Avatar
No, only the 98 had an extra guage output. And that would be in the wrong range. Order another sender from Zip corvette (about $20), tap the block plug and wire to your existing gauge.
Quick Reply: LS1/t56 73 Corvette 12/1/10
