t56 hard to go on reverse
hello guys i'm in the middle of an e36 m3 lsx conversion, the project is almost complete, i just need to finish the cooling and exhaust, my problem is i'm using a pcm harness that came from an automatic corvette, and its super hard to get the car on reverse and keep it from popping out of reverse, any info as how to wire the tranny so the reverse lockout solenoid can work, any info or opinion is appreciated thanks in advance for the help
You can put in a push button with power and ground on the dash or hook up a relay to energize the lockout off of the brake switch. I have mine off my brake switch. The lockout is more for downshifting under power than for braking. That you have to have your foot on the brake pedal to put it in reverse.
