V6 to LS1 Fuel Pressure
What are you guys using to regulate fuel pressure? I have over 100psi at the rail. I'm using a Walbro GSS341 pump, V8 fuel bucket, v6 fuel tank and lines.
Most guys on here are using the corvette filter/regulator for the years 00-2004 corvette. Not sure what the part number is but if you go to your local parts store and ask for a fuel filter for that year of corvette you should be good to go.
Yeah, however, the v6's are return style from the factory. I'd like to be able to use that and have a better fuel pressure regulator closer to the rail.
