Coolant temp adapter to use stock gauge
has anyone used one of these units? says it lets you use the stock gauge and pcm from a single temp sensor...
http://cgi.ebay.com/ebaymotors/LS1-L...ts_Accessories
The 3 wire CTS uses the same connector as a TPS or AC high pressure switch. You may have the AC connector laying around from rebuilding the harness, if not nearly any GM car 90+ will have the proper TPS pigtail. Snip, solder, drive
Pinout
A BLK CTS low ref
B YEL CTS signal
C Dk GRN Coolant gauge
