Cruise Control (DRW)
Hi Everyone,
Is anyone using the cruise control in their swaps? I was reading this http://chevythunder.com/drive_by_wire.htm and then wondering how other folks are running cruise control with DBW (drive by wire).
Thank you.
Thank you.
I have mine set up and it works great. My harness from Speartech had the wires available and I had to get a 4 wire switch, I used a mid 80s GM Turn Signal stalk with the cruise control. I believe there are wiring diagrams in the stickys with pictures of various switches that work. You will also need the right brake light switch.
Pat
Pat
