mustang guys with aje crossmember
are you using transmission mounts like rubber or polyurethane...or are you just bolting the crossmember directly to the transmission?
Nice build sir... What length drive shaft did you end up with going to the 1350 u joint? I know that lengths can vary some but I wanted to get in the ball park to get an idea. Also, from the pics it looks as if your trans mount is tied into the subs? what mount did you use and did it give you a satisfactory driveline angle? Thank you for your time.
