400 - 425 HP on 87 Octane - 6.0L (or 6.2L V8)
Is it possible to run 87 Octane with L92 Heads on a LQ4 6.0L and a Cam to make 400 - 425 HP? Or do I need to run higher octane? Wanted to build a low compression motor. I was told it wasn't a good idea to run a cam and lower octane as well, but will it work and meet my power goals?
as long as your DCR is low you can.... the L92 + LQ4 with dish pistons should have you around 9.6.1 comp..... Your DCR would depend on the cam timing events as well but I don't see why not.... If you go to a bigger cam combined with a wider LSA, your only going to bleed off even more DCR
So I say you should be fine.... Just calculate your DCR.......
