Which suspension spring to buy for my fox body ls1?
Old 08-15-2010, 11:50 AM
LS1SS4ever's Avatar
Question Which suspension spring to buy for my fox body ls1?
I have Fox Body LS1 and I want suspension spring lower but not too much you know ls1 engine is lighter than the 5.0L engine. Which springs do u advice me to buy?
Old 08-15-2010, 12:28 PM
MMorgan9812's Avatar
Coil Overs, adjust what you want it to be
Old 08-15-2010, 09:55 PM
danbap's Avatar
i think i have the aje 150 and they are the wrong ones with my iron block. i have to adjust them so there is just a little bit of tension on adjuster plate when its fully unloaded and my car sits higher then stock in the front.
Old 08-17-2010, 11:23 AM
LS1SS4ever's Avatar
I don't want coil over
Old 08-17-2010, 12:45 PM
kdavis's Avatar
How would a 4cyl spring look up front?
Old 08-17-2010, 04:09 PM
themachasy's Avatar
Get a linear rate spring and cut them to where you want them. Or coilovers.
Depends on what you're going to do with the car. I like coilover setups because you can easily change out springs and springrates to suit your setup and what you're doing with the car.
Quick Reply: Which suspension spring to buy for my fox body ls1?
