What gages run off of the standard ecm output of the ls engines
thas kinda broad question...
short answer is yes...
long answer is depend on the gauge u use...
my autometer c2 tach and speed work off the pcm/vss...my full sweep gauges doesn't work with anything from the ls1...atleast i dunnoe how and see nothing stating so...
Tach and VSS are the only PCM outputs. Theres serial too, but not many people have cracked those
The LS1 oil sender is compatible with most stock/aftermarket gauges. The 98 CTS/gauge sender combo is pretty darn close to most analog sweeps so I recommend it for simplicity. Other options are a remote mounted sender in the pass cyl head or a tapped section of pipe in a coolant hose
That should be all the common gauges related to the engine
