Where is everybody mounting the PCM on First Gens?
Old 08-24-2010, 04:38 PM
69 Ghost's Avatar
Default Where is everybody mounting the PCM on First Gens?
Where is everybody mounting their pcms? I would like to see pics, etc. So far it looks like it will be behind the passenger fender. I also want to know if people are extending their harnesses.
thanks!
Old 08-24-2010, 04:57 PM
Indyjc's Avatar
No pics but mine is mounted in the glove box. I plan to pull it out and mount it some where in the engine compartment. Just remember to mount it where you can get to it if needed. I may end up putting on the pass. side fender. I used an s-10 ecm mount. I think some one sells the harness extensions, maybe ebay? Let us know what you decide. Good luck
Old 08-25-2010, 01:43 AM
myz06's Avatar
Glove box is good for me.
Old 08-25-2010, 08:55 AM
Klimaxx's Avatar
I have mine mounted behind the passenger headlight next to the battery, I used a techrods harness so i had a little extra run for the ecm.. it crosses infront of the heater box and then underneath the fender for the rest of the run. I used a 2003 silvado ECM bracket (slightly modified).. you cant see the ECM with the battery installed, its very clean looking
Old 08-25-2010, 10:05 AM
jweb47's Avatar
Since my 69 has AC, I wanted to mount mine behind the left side headlight. Isn't installed but is tested...
Old 08-25-2010, 11:05 AM
69 Ghost's Avatar
Well I have the drivers side taken with a GTO CAB and the factory engine bay harness relays. The passenger side has my battery and the coolant overflow behind it but I like the idea. The overflow is from a Nova but all the older cars work like the cadialliac sevilles. The coolant bottle fits perfectly inside the fenderwell behind the battery. I have a vintage air setup so I really don't have room in the glove compartment. Looks like I may have to do some wire extensions....
Quick Reply: Where is everybody mounting the PCM on First Gens?
