Blowthrough 6.0 FOX
Old 08-30-2010, 07:58 PM
Cummins Cowboy's Avatar
Default Blowthrough 6.0 FOX
Hello everyone. Im kinda new to this site but its awesome. Just a few questions. Has anyone run the MSD 6010 under boost? does it work good? Planning on running a quickfuel with either twin 70's or a BW S400. Prob go with trick flow heads. Shooting for high 9's with blowthrough carb setup. Thanks for the help.
Old 08-31-2010, 03:22 PM
Speedy911's Avatar
Parish used the MSD 6010 for ignition control on his 5.3 Fairmont. It was coupled with MegaSquirt controlling the fuel(you would have a carb for that) essentially the same thing. It worked out great for him. He ended up getting deep into the 9s.
My mustang used to have a blowthrough carb/set-up. Had a bone stock 5.0 with a MasterPower t-70. I modified a Holley 600 myself for blowthrough. It ran great until I decided to part it out.
Old 08-31-2010, 03:30 PM
71 chevy's Avatar
how much is the quickfuel going to set you back? 900? $1000?
for $1500 you can get the holley hp efi plug and play and it will replace BOTH your carb and the msd6010.
Old 09-01-2010, 04:25 PM
overhere's Avatar
DAMN! i wanted to be the only blow thru 6.0l in a fox!!! i use the msd6010 no problem once you figure it out its easy. its not set up to pull timing during boost but you can do it. and also its in psia which takes a little bit to get use to. but other then that it works fine.
Quick Reply: Blowthrough 6.0 FOX
