1991 S10 LQ4 Project
I've been working on this truck for a long time, it's slowly coming together finally, here is some pics of the progress.
LS1 intake
Interior
Mahle Pistons
LQ4 Block
TH350 trans
Crossmember for CTS V oil pan
CTS V Oil Pan
LS1 intake
Interior
Mahle Pistons
LQ4 Block
TH350 trans
CTS V Oil Pan
A little update. Headers went on alot easier then I had expected. no issues going around the frame all and all they're a good fit. I had to remove the tube on #5 cylinder because my steering shaft is going to need replaced or modified. Here are some pictures.
what kind of rear end are you running? I might be picking up a little newer s10 here soon and doing either a 5.3 or LQ4/9 swap, just trying to peice together everything i'm going to end up needing
You can use either a 8.5 from a newer s10 or a ford 8.8 which are cheap but they are wider then stock. You can just cut the long side of the rear to match the short side and use a short side axle. I paid 175 for a complete rear with 3.73 and discs.
Right now it just has a stock 10 bolt under it. I'm probably going to use it untill I can upgrade, I'll just have to be careful and take it easy! I'm going to end up with a 9 inch under it.
