LS1 Porsche 928
Old 09-23-2010, 06:41 AM
jojomanx's Avatar
Default LS1 Porsche 928
Soon I will be starting this project and hopefully finishing before Xmas.
Original Porsche engine is over 500 lbs and 100 or more HP less than an LS1.
Old 09-23-2010, 12:15 PM
dhknox's Avatar
Good luck! I just finished my conversion of an LM7 Silverado engine into my 1985 928. Automatic transmission with limited slip. It's a blast to drive now that the heavy, low torque Porsche motor is out of there!
If you need any advise I will be more than happy to let you know where I ran into issues and how I overcame them.
Ovrall not a bad swap, pretty straight forward.
Old 02-22-2011, 09:04 AM
ez2cdave's Avatar
I realize this is a 5 month old thread . . . UPDATE ???
On thing that I am concerned about . . .
PORSCHE's are usually close to 50/50 weight distribution, front & rear, from the factory.
The LS1 is probably 150 lb or more LIGHTER than the original PORSCHE 5.0L V8 . . . There may be some EVIL handling characteristics, if your car ends up weight-biased to the REAR . . .
Even a true "50/50" car (the PORSCHE 911 comes to mind) can be a real BEAR to drive aggressively, as it can INSTANTLY transfer from Understeer to Oversteer and vice-versa, without warning . . . BE CAREFUL ! ! !
Dave
Old 02-22-2011, 09:15 AM
Pop N Wood's Avatar
Originally Posted by ez2cdave
Even a true "50/50" car (the PORSCHE 911 comes to mind) can be a real BEAR to drive aggressively, ...
I though 911's are massively *** heavy, like 40/60 dist?
Old 02-22-2011, 09:39 AM
ez2cdave's Avatar
You are right about the 911 . . . Bad example by me . . .
Dave
Old 02-22-2011, 12:36 PM
Pop N Wood's Avatar
My Datsun 240z went slightly tail heavy by the time I ditched the iron block in line 6 for an all aluminum LS2 and added a heavier rear end. The rear weight bias seems to help put down power. I would call the handling anything but evil.
Old 02-22-2011, 01:14 PM
1995blacktattop's Avatar
cool. I always liked those oldschool porsche 928s cause of the arcade game Chase HQ.
http://www.youtube.com/watch?v=glnshAl1su0
Quick Reply: LS1 Porsche 928
