Fuel filter for a system with a return line?
Old 09-29-2010, 12:23 PM
jeepnut24's Avatar
Default Fuel filter for a system with a return line?
What filters are people using for a system with a full return line. IE a truck motor. I picked up a late model silverado filter to match my motor (2002 5.3), but it has some weird fittings on both ends. Id rather not have to switch out the fuel rail to go return less, and Im hoping I can find a filter with normal, or specifically inverted flare fittings on it.
Old 09-29-2010, 12:32 PM
Jim_PA's Avatar
Correction: I used a 35 micron after the pump: http://www.summitracing.com/parts/EAR-230106ERL/
and supposedly you should use a 100micron before the pump.
Old 09-30-2010, 02:25 AM
rsz288's Avatar
See the conversion stickies. Details with pics.
Old 09-30-2010, 07:21 AM
Old Geezer's Avatar
Default That's..
Originally Posted by Jim_PA
Correction: I used a 35 micron before the pump: http://www.summitracing.com/parts/EAR-230106ERL/
and supposedly you should use a 100micron after the pump.
backwards....
Old 09-30-2010, 08:05 AM
jeepnut24's Avatar
Everything there is on the corvette filter. I want a filter without the regulator in it, and off the shelf.
Old 09-30-2010, 09:56 AM
thunderstruck507's Avatar
I use a 05 up Mustang GT filter in line before my pump and I connected it to the hardlines with standard compression fittings. Only downside is needing a new ferule when the filter is changed...but those are very cheap.
Made for a quick, easy, no hassle setup.
Old 09-30-2010, 10:12 AM
cutlass_455's Avatar
I used a filter for a 98 chevy pickup.
Looks like this. Its got them wierdo fittings, but NAPA has the Dorman repair kits to screw into the filter. Then use compression fittings on them hard lines.
Old 09-30-2010, 11:53 AM
Jim_PA's Avatar
Originally Posted by Old Geezer
backwards....
Not from what I've read. I guess I'll just keep running it backwards
Old 09-30-2010, 12:59 PM
LS69TA's Avatar
Why not use the Corvette filter/regulator? Seems like it'd save you some trouble. That's what I used and it worked perfect.
Old 09-30-2010, 04:44 PM
jeepnut24's Avatar
Thats the filter I have.... Any idea on the part numbers/descriptions for the fittings?
Old 09-30-2010, 04:45 PM
jeepnut24's Avatar
$$$$ for a new fuel rail. My motor is a truck motor with a return system, not one of the returnless systems.
Old 09-30-2010, 05:38 PM
I think this is it, from summitracing.
Dorman 800-153
There is different ones, check out the list here, Im sure there is more out there too.
http://www.summitracing.com/search/D...s/?Ns=Rank|Asc
Old 10-01-2010, 07:15 AM
knievel's Avatar
You have been reading in the wrong spots then
Old 10-01-2010, 07:28 AM
Old Geezer's Avatar
Wink Whatever..
floats yur boat....
Old 10-01-2010, 11:49 AM
Jim_PA's Avatar
Yep, you're right. Reading in the wrong spots again. Now I need another damn filter
Old 10-04-2010, 10:50 AM
jeepnut24's Avatar
Dorman 800-153
Thanks. I found a factory GM line that is 8' long with one of those 16mm fitting on each end. Im going to cut it up, bend it and use that. Just need to find a good JIC compression fitting for the ends so I can hook up the AN flex lines to the tank and fuel rail.
Old 10-04-2010, 11:42 AM
97s10ls's Avatar
I just went and found a returnlees fuel rail and injectors for like $15.00 from a member from here. Then bought the vette filter/reg for $35.00.
Old 10-05-2010, 11:45 PM
jeepnut24's Avatar
I wish I could find a new fuel rail for that much. Best I saw was 3 times that much.
Old 10-06-2010, 05:32 AM
Jim_PA's Avatar
Put up a WTB add on the performancetrucks.net sister site. I paid $25 shipped for mine within about 2 hours.
Old 10-06-2010, 12:37 PM
Jim_PA's Avatar
Come to think of it, I ended up trading someone who WANTED a return style, so all I paid was shipping one way.
Quick Reply: Fuel filter for a system with a return line?
