AJE 4L60e trans crossmember for Mustang Fox
Old 10-26-2010, 09:11 AM
STL2SLO's Avatar
Default AJE 4L60e trans crossmember for Mustang Fox
Has anyone used this part? I have searched and everything I have read tells me everybody is making their own crossmember for the 4l60.. Wondering how it fits and if it has enough room to tuck the exhaust up nicely.
AJE site shows the MU-7050 to work on PG, th350, 700r4, 4l60e, c4, aod, and the c6 transmissions.
Anybody have any pics they could share as I haven't seen any in my searching?
Thanks!
Old 10-26-2010, 10:15 AM
71ANTICARB's Avatar
My buddy has one and it looks real nice but he used the wrong tailshaft on his th400 so I don't think he is gonna be using it. It does look like it will clear the exhaust no problem.
Old 10-26-2010, 10:21 AM
STL2SLO's Avatar
If he is using the th400 trans then that is a different crossmember (part number) than I am asking about..
Old 10-26-2010, 10:40 AM
71ANTICARB's Avatar
Gotcha well I'm sure that fit would be about the same. It is very similar in profile as the factory member but I would say that aje would clear the exhaust better.
Old 10-26-2010, 07:46 PM
Z284thgen's Avatar
I just used my ford double hump factory x member. Cut the tack welds on the bushings shell so I could slide it back n forth. Then I took some angle iron cut it to length and used one side of factory mount then welded the angle on the other side drilled a hole and bolted it up
Old 10-27-2010, 09:55 AM
STL2SLO's Avatar
Anybody else have any pics??
Old 10-27-2010, 09:49 PM
ebk06's Avatar
I have an AJE 4l60e crossmember. At least the guy i bought it from told me it was lol. I Dont have any pics here and the car is being worked on at my parents house since my dad has lots of tools. Apparently you have to call aje and order the crossmember because its not listed on there site. Ill be able to get you a pic maybe tomorrow or saturday for sure.
Ill try searching the forum to see if the guy i bought it from still has a pic of it up.
Old 11-02-2010, 09:39 AM
STL2SLO's Avatar
Bump..
Old 11-02-2010, 07:21 PM
E-Works's Avatar
I have an aje crossmember for a 4l60e in a fox and it did not work.
I had to modify it.
I switched to a turbo 400 so if u need it and also an aluminum driveshaft i will sell you both
219 614 5340
Old 01-10-2011, 07:13 PM
mred's Avatar
I had to modify it.
219 614 5340
why would it not work???
Old 01-13-2011, 07:44 PM
STL2SLO's Avatar
^^^^^^ I want to know why it wouldn't work also..
Anybody else?
Old 01-15-2011, 08:01 PM
mred's Avatar
Anybody else?
cause he doesnt know what he is doing
Old 01-15-2011, 08:22 PM
Inbred's Avatar
How much for that aje crossmember?
Old 02-07-2012, 05:21 PM
AllMotorLT1's Avatar
I had to modify it.
219 614 5340
X2 I called jegs and ordered the aje crossmember, shipped it to me and it didn't even come close so I called aje to verify the part # jegs sold me and they said jegs sold me the wrong one and gave the the correct part # I needed to order from jegs.
Well after returning it and getting the one that aje said was correct it still didn't fit about 3/4 of an inch off so I got pissed and just modified mine also.
I am running a 4l60e in a fox with a aje k-member too.
Old 02-09-2012, 12:38 AM
bakomack's Avatar
I ordered one from jegs for 4l60e. Fit perfect and I am using a upr k member. Fit perfect
Old 02-15-2012, 12:25 AM
94'BLKBRD's Avatar
part#?
Old 03-02-2012, 07:07 PM
redws618's Avatar
Does anybody have a pic of the damn crossmember in the car mounted?? I have went through two already and one wouldn't even come close and the second is hell to try and get in, gonna have to be modified some way. Please give a pic!! Lol this is bullshit!
Old 03-10-2012, 07:01 PM
all juiced up's Avatar
mine is way off to and my trans seems to high touches the tunnel on the top of the trans
Old 03-12-2012, 09:55 PM
bakomack's Avatar
I ordered my cross member off summit racing, mu 7050.
Matched the part number from aje's site bolted in perfect.
My upr k member has 2 slots for mounts, I had to put the mounts in the front slot but other than that it was straight forward. How are people having these problems?
Old 03-13-2012, 06:35 AM
bakomac, can you take pics of which way your motor mounts are facing and a pic of the trans mount in the car
Quick Reply: AJE 4L60e trans crossmember for Mustang Fox
