Crazy!!!!05-06 blue gto gauges in 68 camaro??????
Old 11-16-2010, 10:20 AM
firehawk68mcleod's Avatar
Default Crazy!!!!05-06 blue gto gauges in 68 camaro??????
Hey, i have a blue 68 camaro and im doing an ls2 out of a 06 gto... And i thought how great it would it be if i put the bermuda blue gauges in my camaro. Also, i thought it would be great if i had the engine lights that would come on if there was ever a problem with my engine.... So, here is my question..... What computers and moduls do i need to do this? All the under neath dash harness or is there another solution? idk... Sorry about posting here idk where else this would classify thanks.
Old 11-16-2010, 10:52 AM
Nashty's Avatar
It's doable. Check out the thread about the 37 Ford. You need to do some rewiring and you need the BCM.
Old 11-16-2010, 07:04 PM
lizeec's Avatar
Default Yes it is
Look up a member on here by the name samhatco he installed the GTO guage setup in his firebird and got everything to wotk like the factory intended it to and it looks great.
Old 11-17-2010, 08:26 PM
kwhizz's Avatar
Between Dave (my friend that wired the car) and John at Speartech we got the GTO dash module to be fully functional in my 37 Ford build........I'll try and get Dave to pass along the info to help out..........But, I know we had to use the GTO fuel Pump/Sender assy to get the fuel gauge to work.....we also had to use the Body Control Module, and the Parts Train Interface Module......
https://ls1tech.com/forums/conversio...2-install.html
Ken
Quick Reply: Crazy!!!!05-06 blue gto gauges in 68 camaro??????
