Will a 2005 Gto rack and pinon work in a 68 camaro?
Alot of luck. Look at Flaming River
Wat do you mean.. i mount it on the front of the main beam on the cmaro sub frame and replace the front beam with a mandrel bent tube.. im wondering if the turn ratio will work... i can pick it up for 45 buck and it only has 25,000 miles on it
Old School Heavy
I would not recommend anyone try to engineer an untested rack & pinion installation without a solid understanding of suspension geometry in relation to the steering geometry.
If the length is ok to connect to your spindles it can be made to work. You will have to work out the connections to the stock steering shaft. I used a c4 vette steering rack and steering shaft in my 68 camaro and it looks stock.
