Turbo-LQ9-T56 96 Blazer
Old 11-18-2010, 08:10 PM
nleming's Avatar
Default Turbo-LQ9-T56 96 Blazer
Here is a shot from after the flood. I scrapped the 87 longbed S10. Most of everything needed to be rebuilt or replaced.
The new truck, 1996 2wd blazer
Rebuilt GTO t-56: Converted to f-body to use MGW shifter
Rebuilt LQ9, forged rods/pistons, stock crank.
99 f-body brake conversion on belltech spindles
First Mod Video: http://s104.photobucket.com/albums/m...t=P1010174.mp4
Old 11-19-2010, 10:36 PM
greenturtle05's Avatar
Good luck with project keep us posted.
Old 11-20-2010, 01:31 AM
flippincamaro's Avatar
Awesome swap!!! Keep it up
Old 11-21-2010, 07:34 PM
lightning95sc's Avatar
Where did you get the brake conversion parts and do they work on a 1st gen truck?
Chuck
Old 11-21-2010, 10:51 PM
Kory 88Iroc Lt1's Avatar
looks like a cool project. Looking foreward to updates.
kory
Old 11-22-2010, 07:01 PM
nleming's Avatar
PM sent about brakes
Old 11-23-2010, 08:35 PM
phoenix's Avatar
cool build keep us updated
Old 11-28-2010, 11:12 PM
jakerps13's Avatar
Absolutely hate Blazers... but this one looks promising!
Old 12-27-2010, 02:05 PM
IT_SS's Avatar
any update? i've been thinking about picking up a Blazer myself
Old 01-11-2011, 08:52 AM
HydroStream6's Avatar
Update?
Old 01-14-2011, 12:49 PM
nleming's Avatar
Not much to update as the Blazer has been moved to my new house as well as all the parts. I should be finalizing the move in the next month or so and with the new garage some progress will be seen. If you can believe it, the roof decided to leak at my work and land right on my new short block. Some WD40 and fresh oil and everything seems to be cool. Here is a parts pile shot before it all got packed up for the move.
Old 02-10-2011, 01:12 AM
Alvisracn's Avatar
Originally Posted by lightning95sc
Where did you get the brake conversion parts?
Chuck
I'd like info on this also.
Thanks,
Old 02-22-2011, 07:57 PM
nleming's Avatar
got some 245/45r17 cheapos for mock up. Only paid 40 bucks for the pair, hopefully they fit.
Old 02-22-2011, 08:06 PM
nleming's Avatar
Another part for the pile.
Old 02-23-2011, 05:00 PM
yfz
yfz's Avatar
what wheels are those and where did you get them?
Old 02-23-2011, 06:15 PM
Tig
Tig's Avatar
This is going to be good. Nice pile o parts you got there.
Subd
yfz,
They're Gragar Soft 8s, sold through Summit.
Old 12-28-2011, 01:30 PM
nleming's Avatar
Long time on the update but have had a ton going on lately. Wheels are definitely Soft 8s from summit, the brackets for the brake swap were from flynbye and we turned down the rotors to make the hubs. PM me if you would like more info, I will try to be getting on here more now that I can actually work on my truck.
Such a big update I will let the pictures speak for themselves.
Stock width 9" with GM ends
98+ fbody brakes to match the front
Fronts mocked up
Good crossmember clearance, hopefully engine isn't too high.
test fit, hopefully new A-arms give the added clearance for rear of the manifold to make an easy connection. Decent room for a down pipe also
Decided I need one more rim, full size matching spare looks great.
ARP studs
Z06 cam, LS2 chain
LS7 lifters
LS9 Headgaskets
Got rid of the jumbo cal vu mirrors and switched to some strippers, 29 bucks shipped!
Last night's progress...
Old 12-28-2011, 10:28 PM
BLKLS1240SX's Avatar
man this is going to be a fun truck
Quick Reply: Turbo-LQ9-T56 96 Blazer
