How do you tell if the engine harness is a 98?
Old 12-06-2010, 07:37 PM
jkade72's Avatar
Default How do you tell if the engine harness is a 98?
I bought a harness off here thinking it was for a 02 and it may be. The harness has 98C Ls1 in grease pen wrote on both the PCM connectors. The guy I bought it from also threw in the under dash harness and it has 02 LS1 wrote on the big connectors on it. He isn't sure if it is a 98 or 02, he has no idea as he bought them used.
How can I tell if it is a 98 harness?
Thanks In Advance!!!
Old 12-06-2010, 08:11 PM
Rick Speed's Avatar
Find the coolant sensor that is close to the Alternator connector and if its a 3 wire its a 98 .... 99-02 use 2 pin
Old 12-06-2010, 09:20 PM
jkade72's Avatar
You are the man!!! Thanks
Old 12-06-2010, 11:03 PM
Pocket's Avatar
That works, but sometimes the harness has a few tweaks. Another slam dunk method is to pop the PCM covers off and look for a black wire in the #1 and 40 (far ends) pins on both connectors. Delphi kept the corner grounds from 99 to the introduction of GEN IV control
Old 12-07-2010, 12:57 AM
N21923's Avatar
98 had green, 2 wire oil pressure connectors.
Old 12-07-2010, 08:22 AM
WeeWolf's Avatar
98's also had three connectors where'd the engine harness meets the under dash the others only had two
Quick Reply: How do you tell if the engine harness is a 98?
