06' GTO clutch master
Just wanted to let everyone know(if not known already) that the clutch master from a 06' GTO has a flat mounting plate as most of the others have the angled mount and require the adaptor bracket. Don't waste your time with ordering a plate for mounting this master, as you only end up flatening it out. From what I find is that the GTO master will mount up directly to the firewall. You may need a flat plate to cover the opening for the original clutch arm...... I don't know if it helps anyone, but thought it should be known.
